3020 sleeve replace- o-ring area-IDEAS?
BIG JOHN
07-22-2001 06:54:20
Will be replacing sleeves and pistons soon, if o-ring area in block has corrosion how do you repair been told of sleeves? dealer said no Idea.
any ideas???? thanks green guys!
JDTECH
07-22-2001 20:48:44
 Re: 3020 sleeve replace- o-ring area-IDEAS? in reply to BIG JOHN, 07-22-2001 06:54:20
I have never ran into a green one yet that was corroded enough tocause it to not seal up. However, I have heard about a few that the top o-ring land was corroded enough that needed attention. Some of these were repaired with new or used blocks, but I've also heard of the same procedure that the other post is talking about, but I've never witnessed it to know if it paned out or not. Good luck and I hope you don't have to go that route.
wendell
07-22-2001 09:44:02
no problem, machine out the bad parts then, make a collar out of another sleive to match the origional specs. this is a common problem with the 770 Case.
