John Deere BN Tag
where can I get an original?
Prune Picker
07-20-2001 07:26:09
Anyone know where I can locate a BN tag for a '43 or '44 BN? I've heard the factory can re-issue them but it takes forever if done at all. A used tag with the right year serial number would assist in my restoration.
JD70Jim
07-21-2001 19:05:31
 Re: John Deere BN Tag - where can I get an original? in reply to Prune Picker, 07-20-2001 07:26:09
It is the considered opinion of many people that to install the sn tag from one tractor onto a different tractor is a major No-No! If you can locate the good transmission case of a salvage B, one which is the same year as yours, and use YOUR tractor as a parts tractor, you can rebuild the tractor for which you have the sn tag. Otherwise it can sometimes be considered "fraud" or worse.
The usual form this takes is when someone tries to counterfeit a scarce and extremely valuable tractor, such as a Hi Crop or an Orchard tractor and grafts the tag, plus a few essential parts onto a common tractor. Reusing the original case which the tag was attached to is one thing. Taking the tag off and reattaching it to a different case is something else.
Finally, I have seen several places which sell reproduction, original type FARMALL tags, but never have I found anyone who does this for John Deere tractors.
I hope this doesn't cause too much distress, but I have heard this opinion repeated many times.
JD70Jim
