John Deere H
The Undertaker
07-19-2001 06:03:00
Gents:
Going have a look at an "H" down the road. Fella wants $2250.00 Appears to be in very good, not excellent, condition. Haven't established the production date as yet, but the man says a forty decade model. He is not the original owner. Price is too steep, but thought I'd barter with him. Would appreciate advice on major things to look for. The JD's are strangers to me as I'm more familiar with the IH Farmall "H's" and have found parts to be very limited, sometimes non-existent. Would that be the case with this John Deere H?
"TU"
The Undertaker
07-20-2001 12:24:50
 Re: John Deere H in reply to The Undertaker, 07-19-2001 06:03:00
Jim, Karl & Bill:
Thanks to you gentlemen for your advice. I did go down and speak with the man. Learned he had just returned from hospital with heart problems. He invited me and grandsons to have a try starting it, but the little girl wouldn't fire. We turned the cast iron fly wheel around so many revolutions it made me dizzy. Also, closer inspection revealed it needed too much and I'd rather stick to the Farmall line if investing more money in such equipment. At least, if JD's, I'd prefer one with more Oooommmmphh than the "H", besides, I haven't all that much time left to finish off another? My grandsons are having enough problems now disputing as to who gets what out of my relicks.
"TU"
jim
07-19-2001 17:41:57
An h is the only hand crank j.d. that a one arm man can start.I ssen it done yesterday.Can't do his b"s
Karl Bader
07-19-2001 15:58:42
there is a link to the left for tractor prices, that should prove helpful to you, as far as parts they are very plentiful, at least from what I've seen, you can't get everything new, but there is nothing wrong with used parts. gaskets seem to start being discontinued but it is not hard to make your own.
Hope this helps!
Karl
Bill {Antique Acres}
07-19-2001 08:18:43
First of all if it is in very good shape $2250.00 is a bargain. John Deere H's bring a good price. Even junkers with very little hope often bring close to a $1000.00 One thing to keep in mind on the H is if it is a 1939 then make sure it is all complete, because the 39' used some unique parts that won't interchange with the other years. Other than that parts can be fairly easy to find. Also make sure the rims are in good shape as they bring a nice price when you can find them. You also said you have had trouble finding parts for a Farmall H? What do you need? I have yet to run into a part that I cannot get from my dealer or other suppliers. Bill {Antique Acres}
The Undertaker
07-20-2001 12:34:50
 Re: Re: John Deere H in reply to Bill {Antique Acres}, 07-19-2001 08:18:43
Bill:
What would be the prospects of a radiator shutter assembly, rear steering shaft complete with universal joint and the small gas tank with cap and fuel line for it. Then too, I could use a few parts for a water pump hub, i.e., seals and fixed pulley flange with its pin? I've some of these onhand, but some not up to the good tolerances that I'd prefer to invest a lot of work into their installation and later have the job to do over!
"TU"
