PTO on 1120 (early 70's)
Bernie
07-17-2001 18:37:26
Hi,
I need to get at the insides of the PTO lever of my John Deere 1120 (early to mid 70's). Will I need to split the tractor in two, can I get at it from up top, or is there another way? No one around my area of Southern Ontario seems to know.
Thanks,
Bernie French
[email protected]
fax - 519-766-9662
G Taylor
07-18-2001 13:18:09
 Re: PTO on 1120 (early 70's) in reply to Bernie, 07-17-2001 18:37:26
Bernie or R. Drake, the Dealer in Elmira is one of the closest to Guelph. Does your tractor have the two stage foot clutch or the hydraulic pto lever between the gear shifts? What happened to the shifter lever to require service? Are you a member of the Upper Canada or the 1st Ontario clubs?
Bob W
07-17-2001 19:40:04
Bernie-- what are you wanting to do? If you have a two stage clutch you can get at the levers through the round access plate on the left side of the clutch housing. As far as no one in southern Ont. knowing how to fix your problem,I live and work (on Deere) in the same area code!
