JD M starting problem
lee k
07-14-2001 13:18:36
I got this great M last year and it ran like a top. This spring it wouldn't start. Got spark, put in clean gas, cleaned gas filter. It has gas to carb but seems like gas doesn't get any farther since plugs don't appear wet. Float in carb doesn't seem to be stuck. I'm not much of a mechanic but I want to learn. Any ideas would be appreciated.
Bus Driver
07-14-2001 17:17:29
 Re: JD M starting problem in reply to lee k, 07-14-2001 13:18:36
To verify gasoline flow into the carburetor, open the drain on the bottom of the carburetor. If no flow, tap the carburetor lightly with screwdriver handle near the fuel inlet. Float needle may be stuck. On way to minimize sticking needle is to shut off fuel and let tractor run until carburetor is dry when storing for longer periods of time. Don't forget to turn off ignition when engine stops.
