John Deere 2155
Bus Driver
07-13-2001 16:44:36
Ad in paper lists tractor as 1988 model for $11,500. Don't need it, too pricey for me. This model is not listed in Nebraska test book. Just curious, what can you tell about this model tractor?
john2510-3020
07-15-2001 17:24:34
 Re: John Deere 2155 in reply to Bus Driver, 07-13-2001 16:44:36
jim i understand where your comeing from about being to new i just happened to have a jd litterature book by me, everthing else seems to be correct.
john2510-3020
07-13-2001 19:29:48
jim the 2155's did not come standard with cab nor was it an option on a tractor that small, deere felt the tractor looked to top heavy with a cab on it the acab was an option on the 2355's and up though. john2510-3020
JD70Jim
07-14-2001 10:37:20
 Re: Re: John Deere 2155 in reply to john2510-3020, 07-13-2001 19:29:48
According to "HOTLINE FARM EQUIPMENT GUIDE, 1999" they did come "STD" with a cab. As these tractors are a bit too new and too pricey for me, that's all I have to go on. Of course HOTLINE could be wrong, it wouldn't be the first time.
JD70Jim
07-13-2001 18:56:23
It is essentially the same tractor as a 2040, and a 2150. It has the 3 cylinder, 179cid diesel engine, is aproximately 46.6 pto hp, has the 8/4 transmission, weighs about 4970#, came standard with a cab, and was made from 1987 to 1992.
G Taylor Standard with a cab???
07-15-2001 18:47:19
 Re: Re: John Deere 2155 in reply to JD70Jim, 07-13-2001 18:56:23
Any of the 2155,2355 & 2555 came standard with two wheel drive & little else. Any cab was an option or aftermarket. I can't find the litterature but I'm pretty sure a Deere cab wasn't even avalable, just the manditory ROPS. The 2155 was a popular replacement for tired 1020 & 1120's.
