7700 Combine
G FROM MD
10-14-2003 18:17:47
Was just wondering if anybody knows anything about air conditioning on a 7700. What would be easier try to put the r-12 back in it or change it to 134. What would need to be changed over to do this? Looking for the easiest and most inexpensive way. Farming got me on a tight budget.
G-MAN
10-15-2003 08:20:20
 Re: 7700 Combine in reply to G FROM MD, 10-14-2003 18:17:47
Depending on what condition the system is in, R-134A conversion could be relatively inexpensive. If the compressor is good and it has no leaks, you can flush the system, install R-134A fittings, change the receiver-dryer, and go back with R-134A. We have some stuff that we put in that neutralizes the mineral oil used in the R-12 systems, so it doesn't react with the R-134A. We also generally replace the expansion valve, as that is a common problem area. If your compressor is shot, Deere sells Reman units that are compatible with both types of refrigerant, so that is not an issue. Just keep in mind that in a lot of cases, it's not too easy to get an A/C system working "cheap".
Vincent
10-14-2003 20:20:08
Go with 134A refrigerant. I had good luck with it in my swather and tractor. My 7700 was changed already. K-Mart or Walmart sells a kit for about $30.00,which gives you the refrigerant,oil, adaptor hoses, and fittings. It is recommended to drain what oil you can out of the commpressor and put a vacuum on the system before you start. Good luck.
Rob
10-15-2003 06:08:48
 Re: Re: 7700 Combine in reply to Vincent, 10-14-2003 20:20:08
There is a product called Fridge 12 that is compatible with R12. You don't have to replace the compressor, dryer reciever, or the hoses. When the A/C on our Deere combine went out we recharged it with this stuff and the A/C blows just as cold as it did before. I had never heard of the stuff until a buddy of mine who runs a trucking company told me about it, and said was what they were using to replace R12 in the big rigs. You have to have a licence to buy the stuff, but any mechanic who works on A/Cs should be able to get it. Be sure to follow the directions because if you put the too much in the system it won't work. We have also used it in a couple of our deere tractors. It ain't cheap but it works much better than R134.
If it were not for the f%#k$!& United Nations and their environmental BS we would still be able to get the R12.
Rob
10-15-2003 06:14:32
 Re: Re: Re: 7700 Combine in reply to Rob, 10-15-2003 06:08:48
Just went out to the shop and looked at the jug. The brand name of the refrigerant I used in the combine A/C is "Hot Shot"
mark
10-14-2003 20:55:05
if u go to put on 134A we were told on our 4230 we needed a new compresser and it doesne cool as good as R12so id just refil the R12 u can but redteck cans and a kits so u can fill it your self we did that and it works very good and u just buy the cans when u need them mark
Uncle
10-15-2003 04:52:43
 Re: Re: Re: 7700 Combine in reply to mark, 10-14-2003 20:55:05
any old joe can't buy R-12 anymore, right? we had combine charged up with R-12 , cost $200 , only lasted a few days, that was dumb! shoulda used R-134a then we could do it ourselves for alot less
mark
10-15-2003 15:04:14
 Re: Re: Re: Re: 7700 Combine in reply to Uncle, 10-15-2003 04:52:43
hey
no u cant buy R12 any more but u buy redteck or duracool and that is basicly the same as r12 u just top up your compresser when needed u buy your self a kit and it coems with the adapters to hook it to the compresser the hose 2 cans of refrigerant and 1 sealer can for slow leaks we use it and its a good product
