JD6200 Trans Temp Light
Tim
07-12-2001 08:11:13
A JD6200 transmission temp light is on, even at cold engine start-up. Is the trans temp switch directly wired to the light? and where is the sensor located? I checked at the trans filter area and saw four sensor. Your help is appreciated.
Gpower
07-15-2001 06:45:37
 Re: JD6200 Trans Temp Light in reply to Tim, 07-12-2001 08:11:13
SOunds like the sensor just needs to be replaced. There are two sensor up under the transmission on the valve body housing, one will be transmission pressure, the other one transmission temp. The upper one is the pressure sensor, the lower one is the temp. Check with the John Deere dealer to be sure, they are a pain to get to but take time and they will come out. Good luck
