Old JD Plow Info
Air N21
07-10-2001 12:03:05
I am looking for information (i.e. model no., mfg. date, etc.) regarding an old John Deere plow I have. It is a single bottom plow with a coulter. I assume it horse drawn because it has a seat. It has 3 steel wheels; the 2 front ones are adjustable via levers extending back to the seat.
On the shank the number 272 is stamped.
Dennis Winter
03-11-2002 18:35:31
 Re: Old JD Plow Info in reply to Air N21, 07-10-2001 12:03:05
My John Deere Sulky plow has a wooden oak beam, and a steel mow board, and two wooden handles and a small cast wheel in the front. How old is this and what is it worth?
Bob Collins
07-11-2001 10:54:28
Air, What you called a shank is usually referred to as a beam, the beam #272 was used on the New Deere Sulky plow built from 1930-1940. It was built earlier than '30 but didn't use the 272 beam until then. And yes, it is a horse drawn plow. Hope this is useful info to you. Bob
fred quam
06-22-2004 16:26:12
 Re: Re: Old JD Plow Info in reply to Bob Collins, 07-11-2001 10:54:28
I have been seaching for information on an old horse drawn John Deere plow I found in the grove that has the words JOHN DEERE 268 on the beam. It is a single bottom with a small rear wheel. The furrow wheel is smaller than the land wheel. It is only missing the seat. The levers and the wheels work. I think it would plow dirt. Would anyone know how old this plow is and what it would appraise at?
Air N21
07-12-2001 06:55:03
Thanks for the information. I don't know much about the plow, but this will help.
