JD M?
Don n TN
07-10-2001 10:21:10
I have had modern JD equipment for years and lately I have got the itch for a popper but I'm not sure which one. I don't really have the time to restore one of these now even though that does appeal to me and I'm pretty decent with tools, so I guess I want to buy one restored or in really good condition. Where I live is pretty hilly (middle Tennessee)and I need my tractors to have a wide front end so that cuts the selection down some. The JD B's are really neat but the BW is somewhat rare/expensive from what I have heard. The M looks to be overall the best choice in my case as far as I can tell. If I go looking for an M what should I look for (good or bad)? Were there any real problems or weaknesses with this model? Are there any comparable JD models I should be looking at also? Know of any of these in the middle Tennessee area?
Is there anything else I should know about buying a popper?
Thanks,
Don
Richard
07-12-2001 21:56:53
 Re: JD M? in reply to Don n TN, 07-10-2001 10:21:10
I love questions like your's. I'm an MT owner (row crop version of the M)and have some pastures that make me nervous to take the MT across. Well, I agree with the others, that you would really like a newer Dubuque tractor like the 40, 420 or 430. What you haven't heard from the others is that these models, produced in Deere's Dubuque plant vs all the others made at Waterloo, are in my mind some of the best Deere has produced. Experts say, when tuned, they run like well oiled sewing machines. They had a little higher rpm than the Waterloo's. They also have verticle two cylinder engines and a foot clutch, where as the Waterloo tractors had horizontal cylinders and hand lever clutches. Since so many were made, they are relatively plentiful, easy to find. Here in Missouri, an M, in reasonable condition will bring 2000.00 to 3500.00 If you go with an M, I'm sure you will enjoy using it, I use an after market 3 point on the MT, but have also obtained some implements made for the M series tractors. (plow and sickle mower). I just used the 3 point and a pto driven post hole digger on the 4th to drill launch sites for a fireworks display. These M series tractors are over 50 years old and can still produce results of a 24,000.00 dollar tractor. Just my thoughts.
adamHpopper
07-10-2001 20:23:07
Maybe a 40 or 420 is something to your liking
Dan
07-10-2001 20:17:06
Guess a lot depends upon what you want to do with it, and the power you need to do it. There are a lot of JDs in the wide front mode that have a relatively low center of gravity such as the 40, 420, 430 etc. I have an MT which is a great little tractor for small jobs but wouldn't really want to take it on slopes. I also have a 430 u that works great. The advantage of a 40, 420 etc is that most have 3 point standard on them whereas the M was sometimes converted. The 3 point makes it more universal.
Ralph
07-10-2001 20:02:48
I would go with an A or B. I'm not convinced you need a wide front. I clip pasture for my brother with an tricycle A, disk wheels and the back wheels out wide (cultivator width) which is the common configuration. I have been on slopes I would not consider with a M JD unless the rear wheels were out to the maximum which is not the common configuration. I would not venture out these slopes with his 860 Ford either unless the wheels were out wide which they have not been for 30 years. Cast wheels should increase stability and rollomatic or not is probably a tossup. Truth is neither of us should be on slopes this steep with any tractor.
