Paint scheme
doug vose
07-09-2001 19:09:10
i have a 47 or 48 "B" with a roll-o-matic front end, lights, power-troll, and radiator shutters. i am fixing the engine so it is all apart and figured that if I paint it and it doesn't run when i put back together that it will at least look good, so i need to know what needs to be painted what color, from the bolts to the seat, every thing.
thanks for the help
Charles
07-09-2001 20:30:16
 Re: paint scheme in reply to doug vose, 07-09-2001 19:09:10
Seat and backrest, lights, mag. and gen. are black. Axle looks good unpainted or flat black. Wheels yellow, then lots of green everywhere else. The muffler can be painted with high heat black or painted green and watch it burn off. If you replace the gages they should be white face and on the 47-48 model the JOHN DEERE decal is centered on the side of the hood. The rollomatic decal goes on the front of the unit between the top and bottom holes.
Norman
07-09-2001 20:30:08
Doug, Steering wheel black, Rims yellow front and rear, the rear cast wheels yellow, black mag/dist, settleing bowl clear, axles left unpainted or black, lights black, everything else is green except the tires and muffler. I believe it has white gauges. Later
Norman
green48d
12-15-2004 10:46:31
 48 d paint scheme in reply to Norman, 07-09-2001 20:30:08
What is the paint scheme for a 48 John Deere D (12V, w/ starter and lights)?
