4010 D, throttle controls not working
Daryl
07-09-2001 12:13:29
My throttle control on the steering column has to be held in place for RPM's over 500. When I try to place it at say 1500 rpm, the control just swings/falls back to the lower level, at around 500 rpm.
The other throtle, the one on the floor next to the brakes, is absolutely stuck, and won't budge.
Assuming these are two different issues, what can be done for each?
Kerry
07-09-2001 20:09:20
 Re: 4010 D, throttle controls not working in reply to Daryl, 07-09-2001 12:13:29
I had a similar problem with my JD 50, but the throttle arrangement is a little different. On mine, they have a little disc that looks like it's made of brake lining material. I used a piece of leather cut out of the palm of a glove and it has been working fine for about a year now. You can probably use the same kind of material on yours.
Kerry
Deere Jon 2000
07-09-2001 14:17:14
We had the same problem with hand throttle on a 4010D. If I remember right, there is a thin piece of webbed material wrapped around the steering column under the hand throttle tube that is supposed to hold it at the correct setting. Of course, to replace it, you have to remove the steering wheel & dis-assemble the throttle to replace it. As a quick fix, we used a tarp strap hooked under the "saddle" mount bracket, over the throttle tube and then under the "saddle" mount bracket on the other side of the tractor. If course, the tarp strap had to be just the right length to hold the trottle in place, and you had to over-adjust the throttle or lift the tarp strap to get the right RPMs. But on a working tractor, during harvest, it sure beat trying to hold the throttle all the time. ;^)
The foot throttle works by rocking the linkage of the hand throttle. If it is stuck tight, it is likely rusted in place from dis-use. Penetrating oil, tapping the shaft on both ends & heat may break it loose. If you use heat, remember that the area under the dash, behind where you are heating is probable loaded with oil & chaff and a real fire hazard.
