40 Brakes
Joe Badgett
07-09-2001 06:36:35
My JD 40 has very little brakes. Is this a common problem with these old tractors? Can this be a difficult repair?
clooney
07-09-2001 09:35:53
 Re: 40 Brakes in reply to Joe Badgett, 07-09-2001 06:36:35
Joe, what model 40 are you talking about. To answer your question the M-40-420 can be a bit of a problem to get the brakes working correctly but can be done. On my personal 40-S the brakes work smooth & strong enough to lock a wheel in your bare feet. On the 40-S,W,& U the final drives will have to be removed & probably new disks, balls & maybe have the slots that the balls work in reworked with a ball end die grinder stone. The final drive housing that the disk works against should be de-glazed & even roughed up some as well as the apply plate. If all the oil leaks into the final drive housing are repaired & the job done correctly those brakes work good, a little noisy but good.
Joe Badgett
07-09-2001 17:49:46
 Re: Re: 40 Brakes in reply to clooney, 07-09-2001 09:35:53
It is a 40-S. Sounds like a pretty major service, especially for a novice. I would have to leave this for a pro...any takers in the Winston-Salem, NC area?
Clooney
07-09-2001 18:17:10
 Re: Re: Re: 40 Brakes in reply to Joe Badgett, 07-09-2001 17:49:46
Joe, actually with a good manual & the help of this board it is not a difficult repair, just time consuming & you will need good jacks & safety stands. You are going to have a hard time finding a qualified person to repair those brakes, you need someone that has done them before & most of the repair people that are out there now are young & haven't worked on those old 40-S brakes. If you find someone qualified he will probably have a gray beard.
Thane
07-09-2001 09:05:35
I have a 40W, where the disk brakes are in the 'Final Drives'. I had brakes that were almost worthless, so I installed brand new disks. I was very disapointed to find that the new brakes aren't much better. I guess the design isn't as good as the drum brakes that they put on the A's, B's, G's, etc.
Clooney
07-09-2001 19:07:17
 Re: Re: 40 Brakes in reply to Thane, 07-09-2001 09:05:35
Thane, actually the disk design of the 40 series brakes are better than the A,B,G , when they are working correctly they will lock a wheel with very little foot force. Just putting in new disks usually won't make them work like new though. The actuating steel disks & housing surfaces must be de-glazed & all the oil has to removed from the metal parts. The balls & slots in the actuating disks must be in good condition & allowing the actuating disks to apply pressure to the brake disks with enough friction to apply more stopping force as the actuating disks start to rotate.
Thane
07-11-2001 09:12:01
 Re: Re: Re: 40 Brakes in reply to Clooney, 07-09-2001 19:07:17
Clooney, You are right, I only put new disks in, I did not deglaze anything. They do work, just not as good as my Dad's G, or my brother's 730. Maybe one day when I get some 'free time', I'll take the brakes apart and work on them some more. Thanks!
