Brake drum removal
randy
07-08-2001 10:18:51
i have a jd r, the right brake pedal goes to the floor when the brakes are applied. i then removed the unit off the tractor. but i cant get the drum off to inspect the problem. i have tried the adjustment screw while on the tractor, but with
no results. although it seems to work off the tractor. thanks for any info.
Russ
07-08-2001 19:31:59
 Re: brake drum removal in reply to randy, 07-08-2001 10:18:51
Easy to take apart, un-adjust brakes, remove the cotter key and remove the big nut. Slide Drum and shaft assy. out. Inspect and clean the adjusters, Inspect the brake shoes and return springs. Should be easy to find your problem. I would also suggest your remove the brake pedal and lubricate the shaft, so the return springs will have no problem getting the pedal to return.
randy
07-09-2001 15:46:35
 Re: Re: brake drum removal in reply to Russ, 07-08-2001 19:31:59
there is no cotter key, and the big nut is off.
still cant get drum off.
Russ
07-10-2001 09:37:12
 Re: Re: Re: brake drum removal in reply to randy, 07-09-2001 15:46:35
A large cotter should have been thru the nut, but never the less if you have the big nut off, then the shoes are stuck in worn part of the drum. Generally when you back off the adjuster this will pull the the shoes out of the worn part of the drum. Russ
randy
07-10-2001 18:29:23
 Re: Re: Re: Re: brake drum removal in reply to Russ, 07-10-2001 09:37:12
i think it is full of grease. if i hammer on a piece of wood, that is placed on the big nuts bolt, would this separate the drum from the rest of the unit. or would it just remove the gear at the other end.any other solutions any one.
Russ
07-10-2001 20:42:45
 Re: Re: Re: Re: Re: brake drum removal in reply to randy, 07-10-2001 18:29:23
Sorry I thought you had a model A, not an R. My fault. Most JD'S brakes are about the same, but some have the drum nut on the outside, Late Model B and Model 70. Others have the removable gear behind the nut. If the nut is on the outside, then just the drum comes off when you remove the nut. but may be rusted pretty bad. Where is the nut outside or inside? I will call one of my friends in the a.m, and get back to your. Russ
randy
07-11-2001 05:42:45
 Re: Re: Re: Re: Re: Re: brake drum removal in reply to Russ, 07-10-2001 20:42:45
the nut is on the outside. thanks
Russ
07-11-2001 07:38:25
 Re: Re: Re: Re: Re: Re: Re: brake drum removal in reply to randy, 07-11-2001 05:42:45
Use plenty of rust buster around shaft and apply some localized heat to the drum, but don't overdue it, so some tapping, it should come off.
Russ
