6 volt to 12 volt 420 T conversion
Marc Thompson
07-07-2001 16:28:55
How difficult is the conversion?
G Taylor
07-07-2001 18:31:23
 Re: 6 volt to 12 volt 420 T conversion in reply to Marc Thompson, 07-07-2001 16:28:55
If the conversion isn't being done to compensate for a worn engine, weak ignition or out of spec carburation..... Install a 12 regulator set to 14.2 volts & a 12V battery positive to ground. Make sure the coil is 12V or add ballast resistor to use the factory 6V coil. The coil's positive post should be connected to the distributer. Enjoy, but don't be suprised if the starter drive/ringgear has a shorter life span. May need a smaller pulley on the generator & set the cutout to minimum tension required to open points when engine is shut off.
