JD 50 rod bolts
Mike Cates
07-07-2001 16:12:28
I am replacing the rings and rod bearings in my model 50. I notice the rod bolts have castellated
nuts, but no hole for a cotter pin. Are these
supposed to be some type of locking nut? If so,
then they should be difficult to turn and not
loose like an ordinary nut, correct?
Does anyone know how much a set of rod bolts & nuts would be for this tractor? I would really like to replace them at this time if they are not too expensive. (funds are dwindling rapidly!)
BTW, I am new to this list and I appreciate the responses.
Thanks mike
Mike Aylward
07-07-2001 17:05:43
 Re: JD 50 rod bolts in reply to Mike Cates, 07-07-2001 16:12:28
Mike, the nuts on your rod bolts are known as "Marsden" nuts. They clamp to the bolt as they are tightened down. These were a factory replacement nut to eliminate the need and trouble of cotter pins on the rod bolts. If they look ok I wouldn't be afraid of using them again. Hope this helps. Mike
