4010 leaking oil
farmboy
07-06-2001 22:37:29
If a 4010 diesel is leaking a small amount of oil out of one of the small holes near the bottom of the block what could be the culprit?
Don
07-07-2001 08:38:49
 Re: 4010 leaking oil in reply to farmboy, 07-06-2001 22:37:29
Those holes are called weep holes, usualy an indication that new sleeves are in the future and this can cause you to weep as the cost is " Deere"(sorry I couldnt resist that). Each sleeve has a pair of o-rings at the botton to seal water and oil. The sleeves move at a high frequency rate and erode the sleeve and sometimes the block, after awhile the erosion goes under the sleeve and , to keep water out of the oil it comes out the weep hole.
