Battery recomendations??
Le
11-24-2003 16:41:26
Can anyone suggest the best batteries and group size to replace the 2 6V batteries in my 2040?
Thanks
Le
old
11-24-2003 16:48:02
 Re: Battery recomendations?? in reply to Le, 11-24-2003 16:41:26
NAPA sells a number of batterys in the 950 cold cranking amp size that work well I put one on my 190XT Allis and worked very well. Hope this helps. also if you want I'll get you the numbers from the battery just send me an e-mail
Le
11-24-2003 16:54:31
 Re: Re: Battery recomendations?? in reply to old, 11-24-2003 16:48:02
Is that 1 battery or two? For some reason the tractor has 2 6V batteries in series. The cabling looks factory. With the good high amp batteries on the market why would they use 2 6V?
Le
old
11-24-2003 18:07:57
 Re: Re: Re: Battery recomendations?? in reply to Le, 11-24-2003 16:54:31
That was how they did it years ago because 2-6volt batterys would put out more cold cranking amps then 1 12 volt battery but now they have big 12 volt batterys so you can now use just 1 instead of the 2-6volt batterys. hope this helps
