24T
Daryl
10-14-2003 18:02:34
Should the baler continue to function after the shear pin is sheared on the fly wheel? I found that after shearing the pin, I was able to, after bringing the baler to a complete stop, engage the pto, and the plunger arm would operate, the pickup contined to turn and the baler kept on running, but the fly wheel was now no longer connected via the shear pin.
Shouldn't the baler stop baling after that pin goes?
Craig M in NC
10-14-2003 20:08:45
 Re: 24T in reply to Daryl, 10-14-2003 18:02:34
The baler will continue to operate even after the shear pin is broken. The flywheel helps balance the uneven distribution of weight caused by the movement of the plunger head and connecting rod. I have even heard of someone baling a few bales after breaking their last shear pin to finish a field. But that will put a great amount of wear and tear on the driveline of the baler and the tractor used to pull it. You also lose the momentum of the flywheel because it is no longer connected to the drivetrain and that helps the baler to operate.
