I am Lucky!!!
KrisA
07-06-2001 04:56:27
Sorry guys I know it is not proper to glote, but I just had too. The other day I went to run the '51 B. Low and behold rear tire is flat (it was shot to begin with). So last night I got my war uniform on (stained jeans and tshirt) and went at it. I had all tools you guys have recommended for this job. to my amazement with in 2 hours I had the hub off and the tire on the ground. Believe me the tire I took off looked like an original and the hub looked as if it wasn't moved from the factory setting. Basically what I did was use Liquid wrench AND PB Blaster some heat and 8# sledge and a lot of praying. I just wanted to let some of the guys who haven't done this job that miracles can occur when removing wheels. Sorry for being windy so early but I had to tell you all.
KrisA
Chuck
07-06-2001 12:06:04
 Re: I am Lucky!!! in reply to KrisA, 07-06-2001 04:56:27
sounds like you're really into it...good luck...I found the easiest way to do tires...is by removing tire from rim while on tractor....good luck in the future....
Bob K
07-06-2001 07:26:31
When it comes to breaking loose stuck parts, my torch has become my best friend. It may take several heatings and room-temperature coolings with a shot of penetrant several times along the way, but if you're patient enough, you can put the original parts back on instead of having to remove a broken bolt or replace a broken part (this saves money too). Congratulations on a successful wheel change!
Clyde Scott
07-06-2001 05:19:24
I really like your spirit and excitment..!! This is what makes this hobby FUN..!
Clyde Scott - Moultrie, GA
