44-B
Pete
07-05-2001 20:11:19
How the heck do you get your hand in to remove the tappet oil line from the block?
Ben.SO.Tex
07-06-2001 04:10:52
 Re: 44-B in reply to Pete, 07-05-2001 20:11:19
You need one wrench to hole the nipple on the block and one to turn the nut on the line. its a little mean but it will come off. TWO WRENCHS I try to remove one on my 50 with only one wrench on the flare nut and twisted the line and broke it. Lucky for me I had a extra line from my parts tractor. Good Luck
Larry E
07-05-2001 20:26:28
Take housing cover off,I think it is 5/8 or 11/16 end wrench short or stubby It takes awhile after dropping wrench and skinning knuckles and cussing a bit .Have fun
Will
07-05-2001 20:22:18
Just had my 43b all apart. I took the oil feed line off the oil pump and bent it up alittle. (don't do this). But when I put it back together it was a pain getting everything back together to line up. You can get a open end wrench on the fly wheel side in the crankcase. Use a stubby openend. If I remember right it was a 5/8" wrench. I got it running on Saterday just in time for the forth. Keep trying, it took me an hour to get the line back in! God I would hate to do an H. My A wasn't as bad as my B. Remember, take your time and do it right the first time.
William
