Help me I D this tractor
Mel
11-24-2003 15:45:10
Ineed help I D ing this tractor. The tag is missing and the decals are sanded off and painted over. It looks like an M only newer. It has a factory three point hitch. And all the casting #s start with M. Is it an M or 40 or 420 or 430 or even a 330? How does a person tell? Thank you.
Bus Driver
11-25-2003 16:29:47
 Re: Help me I D this tractor in reply to Mel, 11-24-2003 15:45:10
The M has bars in the grille, the 40 and later do not have the bars. But a 40 grille fits the M perfectly. Check the engine block part number- cast into the block. M-64T is the likely block for the M and 40. Post that part number here and that may help identify the tractor.
tom
11-25-2003 01:40:26
Mel,
Here you go:
The M & MT's had adjustable steeting columns, so see if there is an adjusting [lock] mechanism near on the steerting wheel - if the steering wheel is loose, it is probably an M, MT - 40's , 420's/430's, 320's/330's did not. Also, the M 7 MT's had hortizontal grille patterns, all of the 40-430 and 3XX's had vertical grille patterns, also, all of the previoulsy mentioned had two tone [green & yellow] paint jobs - M & MT had had all green - any orange/yellow all paint jobs were industrials...
If the grille vents do run horizontally, then it is an M or MT, - the M Grille had a solid front plate while the MT has an open hole on the middle of it for a huge nuts that is attached to the front support...if the back wheels are relatively small, it is an M...MT's usually had larger back wheels...
If you tractor starts...The M's series did not have live PTO's while the 40, 420, 430, 320, 330 all had live PTO's, these all had 3-pt-hitch's. while the M series had 2-pt "cluster-jobs"...
After you review the posts, let us know where you are going?
tom
Mel in Montana
11-25-2003 09:17:14
 Re: Re: Help me I D this tractor in reply to tom, 11-25-2003 01:40:26
Thanks for all the info. It will be a few days before I get to see the tractor again. It is parked behind a shop about 20 miles from here. I think it's going to be a good find, even though I suspect it might have been a stolen tractor at some time in it's life. Thanks again.
Dale in IN
11-25-2003 07:04:38
Tom:
I have a 1959 430W with a 5 speed transmission and it does not have live PTO.
tom [Dale Henry J]
11-27-2003 05:33:16
 Re: Re: Re: Help me I D this tractor in reply to Dale in IN, 11-25-2003 07:04:38
I'll stick to the M series...sorry for the confusion...
tom [change]
11-25-2003 05:36:41
Correction,
If 37D has a 40 and it does not have a live PTO, then I stand to be corrected...I thought everything changed after the M series, but the 40 was the only model without a live PTO...
tom
Henry J
11-25-2003 06:04:02
 Re: Re: Re: Help me I D this tractor in reply to tom [change], 11-25-2003 05:36:41
tom
If I am not mistaken there are all green 420's in this world and no live pto option. The second year (57) 420 came out with yellow and green and had the live pto option along with the 5 speed tranny.
Happy Thanksgiving
jdman(MO)
11-24-2003 16:12:40
It could even be a M with a 40 rear end, which would account for the 3 point. Another thing check for a live Pto I do not think the 40 has it, but maybe was an option. Russ
Wayne in Tn.
11-24-2003 16:01:03
Mel, maybe we can narrow it down some. An M, Mt, and 40 will not have a waterpump, the 420-320 and 430-330 will. Factory 3-point was only on the 40-420-430-320-330. The M and MT were factory 2-point. The sheetmetal on a 430-330 will have a rounded smooth hood on top, the others will have a raised ridge about 4 inches wide and 1 inch tall down the center of the hood. The 320 and 330 will be a standard looking version with small rear tires like an M. There are several other differences, maybe you could post a photo here or over to the left in the Tractor Photos section.
Dale
11-24-2003 20:27:09
 Re: Re: Help me I D this tractor in reply to Wayne in Tn., 11-24-2003 16:01:03
Wayne, I didn't think the 320 or 330 had a water pump. Do they? You know more about them then I do. I am still learning about these dubdques.
Wayne in Tn.
11-24-2003 21:25:36
 Re: Re: Re: Help me I D this tractor in reply to Dale, 11-24-2003 20:27:09
Dale, I have never owned a 320 or 330 You may be correct. I was thinking they had the same engine as the 420-430???
37D
11-25-2003 04:33:04
 Re: Re: Re: Re: Help me I D this tractor in reply to Wayne in Tn., 11-24-2003 21:25:36
I have a "40U", & I thought a "320" was nothing more than a "detuned"-(engine speed dropped from 1850 to 1650RPM) , "40". Of course the 330 has the "30" style sheetmetal. I have never been aware of any "40" with "live" PTO,but that dosen't mean they don't exist.
37D
11-25-2003 04:39:58
 Re: Re: Re: Re: Re: Help me I D this tractor in reply to 37D, 11-25-2003 04:33:04
Should have added, The 40 series didn't have a water pump & had a 4x4 inch engine, while the 420/430 series had a 4 1/4 inch bore retaining the 4" stroke.
Wayne in Tn.
11-25-2003 06:58:43
 Re: Re: Re: Re: Re: Re: Help me I D this tractor in reply to 37D, 11-25-2003 04:39:58
37D, Tom and all. I have never owned a 320 or 330, so I am in no position to say about them. I do remember hearing they only had a 4 inch piston bore, that would be like a 40 engine. I do know the 420-430 has a 4-1/4 inch bore. No, there were no model 40 tractors with live PTO, and many of the 420 and 430's don't either. I believe a lot of the 5 speeds came with 'live' Don't think I ever saw a 4-speed with 'live'
