John Deere A timing
Ross Boots
07-03-2001 16:55:32
Hello all! I need some help with the timing on my JD A. What spark plug wire goes to what side as you are sitting on it,and which post they go to on my distributor, and how do I time it? Thanks in advance -Ross
Clooney
07-03-2001 17:19:17
 Re: John Deere A timing in reply to Ross Boots, 07-03-2001 16:55:32
Ross, what year "A", what distributor (Wico or Delco) & does it have the big tin cover over the flywheel? Regardless, the top terminal on the dist. goes to the L/H spark plug (#1 cylinder is on the left). If the distributor is installed 180* out of time the bottom wire could have gone to the L/H plug (it will still run with the distributor in 180* out, the wires will just have to be reversed. To time, bring the L/H piston up to TDC (either L/H impulse on the flywheel aligned with case mark (at 3 o'clock behind flywheel) or if the tin cover is still over the flywheel align the depressed mark that is on the flywheel hub with the stamped mark on the bottom of the flywheel cover hole, then with the key on loosen & turn the dist fully clockwise then slowly counter-clockwise until a spark appears on the L/H plug, tighten the dist & your done. I usually time mine running using a timing light but that involves pulling the big tin flywheel cover & measuring & putting a mark on the flywheel at 25*-30* BTDC.
Ross Boots
07-03-2001 20:30:59
 Re: Re: John Deere A timing in reply to Clooney, 07-03-2001 17:19:17
My A is a 49 and it has a Delco distributor on it. It has the big flywheel cover but I have it off right now.I want to sell it, but I had it all tore apart so I could paint it and then I couldn't remember where the distributor was supposed to be set. Thanks for the info -Ross
