40c Pressure plate not engaging
Richard Nieman
07-03-2001 09:11:48
I put new facing and plates in the left steering and also a rebuilt pressure plate. But now the pressure plate dose not engage.Should it be ajusted first? I did not and if so do I have to take it apart again?
Mike
07-03-2001 18:51:53
 Re: 40c Pressure plate not engaging in reply to Richard Nieman, 07-03-2001 09:11:48
I am assuming you mean the clutch will not disengage. If so the throw out bearing needs adjusted. The throw out bearing can be adjusted by removing the access plug on the final drive housing. Also if your problem is the opposite, the clutch will not engage, then it is also possible the throw out bearing is adjusted to far outward and not letting the pressure plate engage. The clutch and band brake need to be adjusted together, if you don't have a manual e-mail me and i will try to explain the procedure.
Mike
