JD 2510 Hydraulics
C.J.
07-03-2001 08:41:01
Is a 2510 capable of handling a front loader. The hydraulic system seems ok once it is warmed up. Can the pump handle the add on.
john2510-3020
07-13-2001 08:12:32
 Re: JD 2510 Hydraulics in reply to C.J., 07-03-2001 08:41:01
i have a 1967 jd 2510 with john deere 47 loader it has plenty of pressure to pick up 2000# green alfalfa hay and do it quick to. mine has its own valves to. dont worry about the tractor not being able to handle the loader, worry about the loader not being able to handle the tractor!!!!lol
john2510-3020
07-13-2001 08:11:53
i have a 1967 jd 2510 with john deere 47 loader it has plenty of pressure to pick up 2000# green alfalfa hay and do it quick to. my has its own valves to dont worry about the tractor not being able to handle the loader, worry about the loader not being able to handle the tractor!!!!lol
Colin
07-05-2001 20:49:49
Sure. I have a 2510 diesel with a 48 loader. My tractor has the 4 piston hydraulic pump with the loader hydraulics hooked into the breakaway coupler. Its a good setup but is not super fast. As I understand it, the 8 piston pump used on later tractors is more desireable.
Dan
07-03-2001 09:38:36
I believe the 2510 had the3020,4020 style front hydraulic pump. should be very capable of handling a loader if it is in good shape. The older JDs did fine on loaders and they had only about 900 pounds of pressure. I believe the 2510 should be up around 2200 pounds in good shape. It would need to have a closed center valve.
