2020
Rusty R
07-02-2001 13:34:13
Hi,
I just bought a 1971 gas 2020 with a 48 loader. I am having trouble with the hydraulic system. When using the remote hydraulics or raising the loader of 3 pt, the whole thing starts to shake like the pump is failing or not receiving enough fluid. I have changed the filter,fluid,and cleaned the sump screen. I have also ordered a filter cover that will allow return fluid to return directly to the filter area for faster reentry to pressure. Do i also need to take remote return fluid back to the filter? WOuld a t-fitting in the line to the filter fitting allow both loader and remote return fluid to renter at the filter? Do i need to plug the connection from the remote control valve and bring the return out the other side?
Also, i have a pinhole leak on the reservoir up front. Could this be contributing to the problems? Can it be brazed? Does the reservoir have to come off to do this?
thanks,
Rusty
Dan
07-03-2001 09:45:22
 Re: 2020 in reply to Rusty R, 07-02-2001 13:34:13
The filter cover you ordered should be for the returen from your loader only, you sholdn't have to reroute anything else. Have you tried checking pressure from your hydraulics? Could also be getting air from the pinhole in the reservoir and that will cause it to shake. If that is the case usually the hydraulic oil will be foamy. Are other hydraulic functions working ok such as steering and brakes? Sometimes a bad steering valve can cause problems in the rest of the system. I'd start by checking the pressure on the remotes. As I remember the remote valves on these are sensitive to adjust.
Rusty R
07-03-2001 10:56:51
 Re: Re: 2020 in reply to Dan, 07-03-2001 09:45:22
Hi Dan,
Thanks for the reply. I dont have any problems with steering or brakes. The fluid is not foamy,but your idea about air from the pinhole leak in the reservoir maybe something to check. I will have the pressure checked also.
thanks
Rusty
