Changin oil pressure on '37 B and other ?'s
Chuck McDonald
06-30-2001 19:33:04
Hey,
Havent been on here for a while cuz i have been working but i had some ?'s about stuff on my B. 1.) I have an oil leak that is coming from the flywheel side inbetween the block and main case only when it is running. Is it possible to pull the rod caps on the rods and split the tracor there without haveing to re ring or hone the motor. Basically can i split it, put a new gasket in there, and then seal it up without haveing to ring it or having the pistons come out of the block.
2.) i also feel that my oil pressure it way too high. It peggs the needle even at idle speed. The manual says i can regulate this with that nut and such at the front of the governor. Is it possible this is contributing to my oil leak? What is exactly involved in adjusting the pressure and should it be done with the tractor running or shut off. Thanks
Chaz
aka "Tractor Boy"
