JD 4010 PTO
Marv
06-29-2001 08:39:01
I have a JD 4010 Gas. The PTO shaft and speed are set for 540 RPM. Is it possible to set it up to operate at 1000 RPM? If so, how? Have an older Gehl shredder i'd like to use with it. The correct RPM speed for the shredder is a 1000 RPM and it doesn't cut to well at 540 rpm. Thanks
Don
06-29-2001 13:27:51
 Re: JD 4010 PTO in reply to Marv, 06-29-2001 08:39:01
Marv, look at the pto stub shaft,note the 4 cap screws . remove them and bolt the 1000 rpm spline on and you are set. Make sure when you go back to 540 that you push and turn the shaft to line up the gears before you tighten the bolts,otherwise you will shear the shifter pin and will have to split the tractor, also check these bolts often and make sure they stay tight. Don
