Can you sleeve an A?
linny
06-28-2001 20:53:16
Finally Im down to the block and I know one cylinder is gone so the question is "TO SLEEVE OR
NOT TO SLEEVE"?
Will
06-30-2001 17:42:31
 Re: Can you sleeve an A? in reply to linny, 06-28-2001 20:53:16
YES it can. But the price! I was told $400 a hole! NOT. Buy another block
Karl Bader
06-29-2001 06:28:50
You sure can! I had the option of boring out to .90 or sleeving back down to standard size. I was told you can bore out to 1.25 at max.
Hope this helps!
Karl
Rollo
06-29-2001 04:54:08
You bet you can. I did it on my '48 A. The pitting was so deep, and it was bored out oversized already, that I had no alternative. It gave me a chance to go back to standard size. One word of caution: All machine shops can't do the job. They don't have the equipment to hold the block properly. The good news is that most machine shop people know each other and can usually point you in the right direction.
Clooney
06-29-2001 02:34:19
Linny, yes it works well. Should you? Depends on the condition of the pistons, if thay are good then sleeves are in order, if you need pistons then a rebore & new pistons are the way to go. The price isn't much different either way depending on where you get the machine work done.
