44 Model D
Josh de Zwart
10-14-2003 17:43:22
I recently purchased a 1944 model D and have a few questions that one of you might give me an answer on: (1)There is an Am meter on the dash and the 2 wires are connected to nothing. This is a manual start "D" and it has no Generator. Does it suppose to have a generator? Or was The ammeter just for "show"? I started the "D" on the trailer and drove it into the workshop. When I removed the (very) old engine oil it was mixed with water to a grey-ish sludge. Can't find nowhere a crack in the block on the outside. could this be a normal condensation thing or do I have a internal crack or blown headgasket? (engine ran nice though....) Thanks in advance for any advice to this "D" novice in Calgary, Alberta.
Clooney
10-14-2003 18:51:59
 Re: 44 Model D in reply to Josh de Zwart, 10-14-2003 17:43:22
Josh, if it has any holes or other indication it had [or has] lights it probably had a generator at one time.
~Deere offered a lights [with generator & ammeter] option on the hand start D's.
~If it has a fan shaft pulley it also probably had a generator.
~If it had a generator it also had a battery box & battery.
~If it had a generator that ammeter was wired between the generator cut-out relay & battery.
~You can either remove all the electrics & run it as a hand start [no lights] tractor or find the proper generator & lights & rebuild it to factory electric specs. [let us know & we can talk you through the re-wiring].
~On your water problem?...It is probably just rain water that entered the engine but you never know what lurks inside..Do an oil change & run it a while to see if the water problem goes away, if it doesn't, you might have an internal crack or head gasket problem.
~Those D's had a water valve on the side of the carb that was used to add water from the cooling system to combat detonation..MAKE SURE that valve isn't turned on, [or seeping] as that will add water to the crankcase. Or better yet plug it off.....
[email protected]
