Greasing fan bearing, Model B, What is fan dampener for?
Bob Weber
06-28-2001 17:13:07
Got a couple of questions about a Model B. First of all, how is the front fan shaft bearing greased on a Model B? Just pull out the pipe plug on top of the housing and dribble some grease in? What type of grease is used? And to satisfy my curiosity, what is the purpose of the spring-loaded disks that drive the fan? I guessing it's just to dampen out impulses from the engine to keep the fan shaft or something from breaking? Can anyone enlighten me? Thanks!
Chuck
06-28-2001 20:14:47
 Re: Greasing fan bearing, Model B, What is fan dampener for? in reply to Bob Weber, 06-28-2001 17:13:07
you can put a grease fitting in place of the plug. The spring loading hold the right tension of the shaft bearing and also allow rather easy replacement of the blade.
