48 B Leaking Oily Gas from bottom of Clutch???
Blair Mahar
06-28-2001 16:50:58
I just filled the gas tank on my newly acquired 48 B and noticed that I have a dripping leak of oily gas coming from the bottom of the clutch housing. Can anybody please enlighten me as to what is going on? Thanks in advance.
B. Mahar
07-09-2001 05:55:50
 Re: 48 B Leaking Oily Gas from bottom of Clutch??? in reply to Blair Mahar, 06-28-2001 16:50:58
Thanks for all your help.
B. Mahar
phil
06-30-2001 14:19:47
I don't think the oil pressure fuel valves were original equipment in 1948, I think they became standard on the 50, 60 series. Anyone know for sure? Some older tractors were retrofitted.
Dean E.
06-30-2001 03:15:50
I had the same problem!I have an automatic gas shut off that works with oil pressure.There are a set of diaphrams in the top of the sediment bowl,they need to be replaced.I went to my JD dealer he ordered them I think they were about $3.They were easy to install.Alsothe crankcase filled with gas so oil and gas run out of the bottom of the clutch pulley,so good luck! Dean Minn
missouri mark
06-29-2001 18:48:57
Gas can also come from the gas shut off,some have a auto shut off that works off oil psi.If you have a oil line that goes to the sediment bowl check it.
Rollo
06-29-2001 05:00:10
Probably, the float and/or needle in the carburator doesn't work properly, and they are allowing the fuel to flow into the cylinders, and on into the case. Pappy is right. It could blow up if you start it!
Pappy
06-28-2001 23:05:10
If the leak is out of the bottom of the clutch pulley, you have a problem of fuel leaking into the crankcase and running over.Repair this before you try to start the engine!!! Don't want your engine to be in a different zip code from the tractor.
