6 speed 50 B shifter question
greg
06-28-2001 06:09:23
The gearshift is very loose and lifts up without coming all the way out. But it loses contact inside and makes shifting gears a guessing game if you lose your place. Can someone please describe what needs fixed in order to secure the shifter lever so it will stay in the same gear as the tranny?
Bob K
06-28-2001 08:56:57
 Re: 6 speed 50 B shifter question in reply to greg, 06-28-2001 06:09:23
It sounds like the snap ring on the bottom end of the shift lever has come off inside the transmission allowing the lever to pull up out of the shifters in the transmission. You'll need to take the shift quadrant off the crankcase to check. I don't think you'll be able to fix it without opening it up. Good luck.
