Generator question
Wayne
06-27-2001 15:20:00
On a car if you unhook the battery cable the car will continue to run if the generator or alternator is charging. I have a "G" and it has a distributor. If I unhook the battery it dies.
Should it continue to run when the battery is disconnected. Had the generator checked and it is putting out about 10 amps.
Clooney
06-27-2001 17:32:13
 Re: Generator question in reply to Wayne, 06-27-2001 15:20:00
Wayne, yes it should continue running but will probably have to be on high idle to do so as those generators don't put out much at idle.
Sometimes Wrong But Never In Doubt
06-27-2001 18:42:49
 Re: Re: Generator question in reply to Clooney, 06-27-2001 17:32:13
Many alternators will be damaged if the battery is disconnected while the engine is running. The condition is called an uncontrolled open. The alternator depends on feedback from the battery for the regulator. If the battery is disconnected, the alternator will charge at such a high rate as to damage the built-in diodes. Just made these comments to perhaps save someone some grief.
