DLTX 71 on 1934 A
need some help
10-14-2003 17:31:49
trying to get a JD A running right. the valves were sticking, had the head re worked. tractor still spits back through carb unless the choke is about half closed. ihave went into the carb and cleaned out all of the jets and air passages dont have a book need to know about float height any helpwould be nice
Duane Larson
10-14-2003 20:04:18
 Re: DLTX 71 on 1934 A in reply to need some help, 10-14-2003 17:31:49
need some help,
Clooney and John T have covered the bases, but I will note that your fuel-burning 1934 A came with a DLTX 8 brass carb, and the DLTX 71 is designed for a late gas-burning A. There are some internal passage size differences, and differences in the economizer system. That said, I doubt your spitting problem is caused by using the 71 and not the 8. Sounds like it may be running a bit lean. The load needle should be about 1 turn open, and the idle 1 1/2 or so. Also, wiggle the throttle shaft around to check for looseness - it may be introducing unmetered air if the bushings and/or throttle shaft are worn and need replacing.
Tim
10-14-2003 23:48:05
 Re: Re: DLTX 71 on 1934 A in reply to Duane Larson, 10-14-2003 20:04:18
I had the same problem on my 51 A, i too thought it was in the carb. I had two diffent people go through it. After both times it still did the same thing, finally irritated me so much that i decided to just rebuild the whole engine, come to find out that the guy i bought the tractor from decided to put some diffent springs on the valves. Made my valves sit there and bounce when they closed, and spit back up through. Dont know if this will help but wont hurt to check into it
John T
10-14-2003 19:33:36
I hope the new valve job didnt get the valves too close on tolerance but its probably okay and have you checked their lash adjustments????
On the carb, first, is there sufficient gas flow getting into the carb and filling its bowl?? If not, there could be a restriction in the neelde valve and seat, the side inlet strainer, the sediment bowl assembly, or the tank outlet. With the gas on at the sediment bowl, open the carb bowls lower drain cock/plug and see if a continuous gas stream about 1/16 inch diameter flows out a couple minutes to be safe n sure. If not, post back and I will post my fuel flow troubleshooting tips, but basically start at the carb and work upstream until you find the cause of any restriction. You have to have good continuous flow out the bowl per the above before shes gonna work right.
Is the choke butterfly plate tight on its shaft and not free to flop around and does it stay put per where the external settign is located???
On the carb, a soaking and boiling until the cows come home often wont cure the problem if theres still clogged passages until you remove the brass drill plugs (usually requires heat) and then use the proper size long aircraft drill bits NO. 40 and No. 53 to clean out the passages behind them. The Roberts Web site
Link
shows the drill plug passages and what size bits to use. You just use the bits on those passages and dont drill too deep and use the right sizes for the holes as shown. The rest of the smaller passages I use steel guitar strings or welding wire to clean them out.
Did you remove and clean the main center vertical brass nozzle???? often if its clogged it can require choke to get sufficient fuel to run. Usually you have to slightly drill its center bore (if necessary depending on what carb and its nozzle bore diameter) or just use a tap if you have a tap size that will fit without drilling, to cut threads cut into the inner bore. Then use a long bolt screwed into those new cut threads backed up with washers and nuts to pull/extract the nozzle down and out. Dont push or bend at the nozzles top up inside the carb cuz it can bend or distort easily. Once removed, you need to clean out ALL ITS LIL SIDE HOLES and clean and polish it and all the holes and bore. A clog there can cause it to get insufficient fuel requiring choke. Replace that spring that goes between the bototm bowl center and that nozzle to keep upward pressure on it.
I set the float to where they shut off the gas when they are approximately level.
I havent gone into possible ignition problems, this is enough for now until youre sure the carb is okay.
Post back or e mail [email protected] any more questions and we will try our best to help.
Good Luck n God Bless
John T Nordhoff
Clooney
10-14-2003 18:36:53
NSH, it sure sounds like you missed a passage or transfer hole when you went through that carb [not all the holes & passages are shown in the online pictures].
~Send me your E-Mail & I will send you a carb breakdown showing the passages that need attention.
~If the engine valves are working correctly now your problem is almost always caused by a plugged passage in the carb [especially IF the choke partially back on makes it run better.
~On the float level? ... Just turn the float bowl over & set it level [parallel] with the top of the float bowl with it hanging on the seated needle valve.....
[email protected]
