JD 310 Missing when warm
Dick Olsen
06-26-2001 22:04:09
I have narrowed to the # 2 cylinder. I cracked the injector lines while it was running bad. Number 1 & 3 caused a definite drop off in the engine, but #2 only caused a slight drop.
Starts good, runs great for 10-15 minutes, looses power or missed until cools down.
Backround.
Rebuilt injector pump and injectors.
Clean and checked fuel system (diesel)
No bubles in the radiator
I pulled the valve cover and all looked ok. Did not check clearances.
I am worried it may have a piston ring, or liner problem.
Please tell me I am crazy..... ..
Dick Olsen
jonathan
06-27-2001 17:43:54
 Re: JD 310 Missing when warm in reply to Dick Olsen, 06-26-2001 22:04:09
with the valve cover off, turn over the engine until you get the #2 valve rockers loose....or check to see that they do indeed become loose....cant really check clearances by just looking at the rockers !!! .014 intake .018 exhaust
