JD 40 transmission
kkreek
06-26-2001 19:03:14
Am restoring a JD 40V which is not a real popular
tractor. This is not my first restoration, but
since this is a special tractor, I thought I would
go all the way. The transmission is coming apart
to be cleaned, any bearing and seals replaced,
etc. My question is the paint inside the trany.
I've seen them painted yellow inside and
understand that this was to seal the inside. This
one is green inside. Is this correct, and is this
the same paint as the outside? Thanks in advance. kkreek
Kevin W
06-29-2001 10:15:27
 Re: JD 40 transmission in reply to kkreek, 06-26-2001 19:03:14
do not paint the inside of case!what you see is the casting paint used at the factory. besides it`s full of oil and won`t rust+whose going to see it any way.hope this helps!
