Boxblade 3pt hitch
chuck seagraves
06-26-2001 11:36:24
I have a 49 A with 3pt hitch and when backing up the lower arms bend from the load. If I beef up these arms will I break something else or put undue strain on the top link mount? This is a homemade setup but seems to work okay when dragging the blade. I have looked at the "Hokey Hitch" and like their setup much more because it dont block access to the oil fill and looks beefer. Also I noticed they dont chains to keep the thing aligned. What keeps their system from getting off to one side or the other?
MN Bob
06-28-2001 06:07:01
 Re: Boxblade 3pt hitch in reply to chuck seagraves, 06-26-2001 11:36:24
Chuck; Dont bet the farm on it but when you back up a tractor all the weight shifts towards the back. (ever really mire your tractor down trying to back out of a wet spot?) This may be what causes the bending, the blade is biting harder and creating a larger load on the arms. If you can control the depth in a free float manner it should help. Just my thoughts, Bob
chuck
06-28-2001 06:50:29
 Re: Re: Boxblade 3pt hitch in reply to MN Bob, 06-28-2001 06:07:01
Bob you are exactly right. Maybe I need to just use the 6ft scrape blade when I need to back up to move loose dirt. This is new to me with a boxblade and the owner was telling me about bending the arms when trying to reverse. I never had a problem with the old scrape blade.
