What will have the same engine as a 3020?
Barney----South
06-26-2001 03:36:03
I need a block for my late model 3020. I have already found out in here that a JD 500 backhoe has the same engine, but a local JD dealer said he thought the same engine was used in other things as well, like the Hi-Boy sprayer. If anyone knows anything about this, I'd sure like to know. Thanks in advance; Barney----South Ga.
Wheres DAVE WTW
06-27-2001 09:49:30
 Re: What will have the same engine as a 3020? in reply to Barney----South Ga., 06-26-2001 03:36:03
He'll KNOW
Chances R
06-27-2001 04:11:00
At one time I thought I heard a 3300 Combine had the same motor???
bozo
06-29-2001 19:59:16
 Re: Re: What will have the same engine as a 3020? in reply to Chances R, 06-27-2001 04:11:00
The 3300 combine engine is the same as the 2530 engine. 219 cu in? Several other unit use this engine also.
bozo
06-29-2001 20:01:46
 Re: Re: Re: What will have the same engine as a 3020? in reply to bozo, 06-29-2001 19:59:16
Meant to type 2520.
Mike Aylward
06-26-2001 04:45:53
Barney, to my knowledge the engine was not used in any other agricultural application. Good used blocks are hard to find. If you have a John Deere industrial dealer near you I would go to them and check the part number of your block on their Master Part Index. That will tell you what machine it was used on. Hope this helps. Mike
Barney---South Ga.
06-27-2001 03:25:05
 Re: Re: What will have the same engine as a 3020? in reply to Mike Aylward, 06-26-2001 04:45:53
Thanks Mike, I'll do that. Barney
