JD A steering rod
linny
06-25-2001 19:02:30
can anyone tell me how to pull the steering rod on my '46 John Deer A.
john
06-25-2001 20:17:20
 Re: JD A steering rod in reply to linny, 06-25-2001 19:02:30
Remove the steering wheel and half moon key. Remove the hood housing on the very front and top of tractor( 4 bolts) ,underneath you will find the steering gearbox. Remove the two bolts on the cover and while someone turns the steering column hold your hands under the cover, the steering gear worm drive will push the cover and bearing out along with the steering shaft. Then just spin-er-on out. Takes about 3 mins.
