JD B Carb will not adjust on Idle Mix Needle,Carb Rusty Inside
John
06-25-2001 19:00:10
Looking for Information on Carb on 1950 B DLTX67 The Carb I Have was not on tractor when I got it and was very rusty after many hours of cleaning,Sand Blasting,Soaking in Carb Cleaner and Muratic Acid Carb after Installing Rebuild kitThe Tractor Runs very Good at High RPM but wants to Stall at Idle. I Wound like to find Infomation on Cleaning of Passages and Does any One Know of Something to Dissolve Rust in Passages that Might be Blocked? Thanks John
John
06-26-2001 18:00:17
 Re: JD B Carb will not adjust on Idle Mix Needle,Carb Rusty Inside in reply to John, 06-25-2001 19:00:10
I would like to thank the Three Persons that replied and to let them know That the passage in bowl under brass plug was rusted shut and now tractor runs great.
Thanks John
Clooney
06-26-2001 14:57:21
third party image
John, this is kind of a generic breakdown of a DLTX carb & the passages that need cleaning. Some pasages are not in all carbs so if your carb doesn't have a paticular passage that is shown don't worry. Make sure you clean the little holes in the side of the bore at the throttle plate area.
gary
06-25-2001 19:15:19
John,
You are probably on the right track, it is essential to get those passages drilled out. There are bits available from Roberts Carburetor, and there is a gentlemen on this board (Clooney) who helped me out with a diagram showing exactly what needs to be done. My tractor is older and I don't think we have the same carb., but I imagine they are somewhat similar. I would send you the diagram if I could, but I already printed it out and deleted it. I used pipe cleaners to ream the holes out on mine, but I think that worked only because they weren't gummed up with varnish all that bad.
Hope that will get you started until some better info comes your way. Good luck!
gary
Spoker
06-25-2001 19:12:18
John it is a simple passage inside the bowl which might be giving you the problem. Remove the bowl and remove the brass screw which is in the side of the main nozzle body. Take a very small drill bit and open the passage behind the screw, into the main nozzle area. This passage is very small and do not drill out any metal. This will let the tractor idle if the rest of the idle circuit is open. If you need any more info I will try to e mail some info out of the Marvel-Schebler service manual
