4010 pulling questions
Case Guy from F
06-25-2001 18:49:11
My dad and I pull case tractors in Floida. We have a friend that is a J/D guy that wants to pull with the big boys in 10500# class. Our rules allow for tracxtors up to and including 1965. He has found a 4010 tricycle front tractor. My questions are. How much would a 4010 weigh dry? How well would it do against Case 930, Farmalls 660,600 and J/D R,720,820. Thanks in advance for answering the enemy
gray4010
06-26-2001 20:06:19
 Re: 4010 pulling questions in reply to Case Guy from Fl., 06-25-2001 18:49:11
you can get a 4010 all the way down to 5500# if you want to. around here (pa) our 10500 class has a lot of turbos in it (ford 9600 ac's ih 966-1066)(your year restrictions may elimimate these?) a naturally aspirated tractor has a hard time competing. open rpms and mph? what restrictions are in your rules? if your not allowed to add a turbo, think about a gas tractor. I have lots of 4010 pulling parts for sale. write if you think you'll need any.
Case guy from Fl
06-26-2001 22:27:48
 Re: Re: 4010 pulling questions in reply to gray4010, 06-26-2001 20:06:19
Our rules for Stock and Antique classes have a 3mph limit no turbo's low gear only. Stock must pull from a drawbar and no hanging weights only bolt on factory frame or wheel weights. 8500# and up 20" pull height max. Antique class can use suitcase weights and do not have to use drawbar. No other classes at this time. Allowed 10% over factory rpm. Hp is not a factor traction is. The competition for this 4010 if my freind gets it would be a Case's 930,800 Farmall's 660,600,wdr9 J/D's R,720,820. How would a 4010 do against these?
richard
06-26-2001 16:20:31
i pull an 820 an have no problem with the 4010's or 4020'2. 660 ih are not a problem. super 99 olivers make alot of noise but they fall short. i pull 2nd gear in 8500-10500 an low gear in up to 15000. just an opinion but i would buy a 820 or 830 if he wants to stay with the green.you"ll have alot more fun an make alot of people mad. later richard
john
06-25-2001 19:49:40
I would say you boys would be looking for some green tractors. It would probably not be such a problem getting under the 10500 weight and you are looking at a tractor that could probably turn around 100- 125 horses without a lot of modifications. And if it has a power shift..... woo hoo. I may be wrong but i would say he would be looking right
JD70Jim
06-25-2001 20:39:18
 Re: Re: 4010 pulling questions in reply to john, 06-25-2001 19:49:40
A 4010 won't have powershift, but a 1964 or 1965 4020 certainly might have it and still be older than your 1965 year specification!
Branded
06-25-2001 19:37:06
No problem. Let him try. The only one he will not out pull is the 820 and a close pull with the 720. So go ahead try him out for size.
