J D 40c crawler serial no missing
Richard Nieman
06-22-2001 07:54:21
I have a 40c crawler that is a four roller,first one made was 6/16/53 no62264.But with the serial plate missing on crawler I can't get any closer to its real serial no. Is there any place I can look for a no?
jCarroll
06-23-2001 11:46:12
 Re: J D 40c crawler serial no missing in reply to Richard Nieman, 06-22-2001 07:54:21
You can get VERY CLOSE without much effort. On the right side of the engine block, just to the rear of the hydraulic pump is a number stamped into the block (probably 5 digits on your 40C). The numbers are stacked vertically, so twist your head 90 degrees to read it. There is a very close relationship of the block number to the serial number for Dubuque tractors.
Then go to Todds Tractor pages at:
Link
and go to the serial number table and see where your block number falls. this should pinpoint your serial number within 4 or 5, and also give you the week it was manufactured.
Further, i understand (haven't done it myself) that with the block number and your local JD dealer's help you can get a new serial number plate issued from Deere - looks different from
