Fluids
Dave
06-21-2001 17:15:20
I have a JD 1946 model A serial number 567742. Can anyone tell me what type gear oil it takes. Also what fluid goes in the lift. It is a power troll. I saw a post here some time back that said 30 weight motor oil. the JD dealer said he wasn't sure but he thought it used hyd. fluid. Which is correct? Thanks for any help.
Fred
06-22-2001 15:59:31
 Re: Fluids in reply to Dave, 06-21-2001 17:15:20
My owner manual for my '48 JDB states: Your tractor is equipped with a power lift or Powr-Trol. Check oil level, add S.A.E. 30 oil at filler opening... Gear oil, 0 degrees and up 90 wt. Below 0 degrees, 80 wt. This means use 80/90 wt like Gman said. Good luck with it.
Gman
06-21-2001 19:03:37
Dave I think the owners manual calls for 20w motor oil,I use motor oil or hydraulic oil,and 85w-90w in rear end. gman
