Hey Clooney, Couple more clutch bushing questions....
Toaster
06-20-2001 21:11:31
How does a guy remove the brass bushing from the belt pulley hub. How does he re-install a new one? Do you need a press or can you tap it in with a hammer? When you hone it out, how much do you hone it? This is on my JD AO #280743. Thanks for your help.
Clooney
06-21-2001 15:39:29
 Re: Hey Clooney, Couple more clutch bushing questions.... in reply to Toaster, 06-20-2001 21:11:31
Toaster, I have cut those bushings out with a hacksaw blade by putting tape on one end of the blade then cutting the bushing almost through in 2 places. I have tried pressing them out but usually end up expanding them instead pressing them out. If I have a large tap that will fit I will thread the tap in & drive the tap & bushing out with a brass rod. I don't have a reamer of the correct size for most of those bushings so will usually either set it up in the mill or take the bushing & pulley to my local machine shop & have them do it. The bushing is best pressed in with a center mandrel but I have driven them in with a driver from my bushing driver kit with good success, every once in a while I will get lucky & not have to re-size the bushing after pressing it in but not very often.
shyla
08-30-2002 02:06:28
 Re: Re: Hey Clooney, Couple more clutch bushing questions.... in reply to Clooney, 06-21-2001 15:39:29
Question what is a bushing and what does it do my ford f-150 will hold in gear or grind and also, when the clutch is released and you push it into gear it starts to roll foward and i was told that it is a bushing any idea or could it be something else????? ? just had replaced clutch about three months ago..
