Axle Drain Plug
George
06-19-2001 10:25:37
What size square driver do I need to remove the axle drain plug on an "A"? Also, where is the fill for the transmission and axle?
Pappy
06-19-2001 11:38:12
 Re: Axle Drain Plug in reply to George, 06-19-2001 10:25:37
The square drive plug is 3/4". You can use a 3/4" socket handle, or I use a 3/4" socket adaptor fitted onto a 1/2" handle. Drain both the lower plugs. The filler cap is just above the PTO shaft and to the right. It's a pipe cap. This fills both the transmission and differential. It will take about 7 gallons of 90 wt gear lube. Have fun!
