A all fuel 3 pos valve-help
MN Bob
06-16-2001 13:51:14
I cannot shut the fuel off on my A all fuel. I have the sediment bowl and 3 position valve off. Can anyone tell me how to free up the 3 position valve? It is stuck in the all fuel position. I have tried soaking in gas, spraying carb cleaner,WD 40 and heat. thanks, Bob
Ben.So.Tex
06-17-2001 19:32:39
 Re: A all fuel 3 pos valve-help in reply to MN Bob, 06-16-2001 13:51:14
Bob If you take the valve off, remove the nut, there is some packing behind the nut, the valve sould come apart, (I had to use some carb cleaner on mine), Sand the valve and the inside of the housing with some FINE sand paper or emery cloth. Do not over sand it. when putting it back you can use a Oring if you cant get the packing, I had to do this to mine a couple of weeks ago, and it works fine now. my 2 cents Good Luck Ben
Bill
06-17-2001 17:36:43
Try soaking it in a carb soak bucket
Larry E
06-16-2001 19:26:53
I think these are on a taper like a gas cock for natural gas.need to tap on it to get apart try light sanding or laping compound and turn to pieces in opposite directions and make better fit and maybe quit leaking
