G magneto
G-man
06-15-2001 20:35:21
No spark from Wico magneto. Cannot get magneto off. Should I replace condensor? How can I test the condenser? Do I need the charged wire from the generator to the Wico cover side terminal? What is this for? How can I check the coil without removing? Side terminal from generator on Wico cover has 22 guage steel strap that is not connected to anything inside magneto. What is this for? Points look OK. What is the likely culprit?
Pappy
06-15-2001 21:53:02
 Re: G magneto in reply to G-man, 06-15-2001 20:35:21
I'm not an expert on magnetos, but did just re-work a Wico X for my son. You do not need the "charged wire" going to your magneto side cover. It's useless. The metal strap on the side cover was a "kill" switch and originally had a were running from it to the points/condenser. Trying to test a condenser is questionable. If possible, clean the points and try a new condenser. Adjust points to .015
