630 Carburetor
Tugboat
11-23-2003 17:42:25
My friend has a JD 630 that has two small copper lines connected to the carburetor other than the fuel line. What are these for? He thinks these are related to a problem that he is experiencing with fuel in the crankcase. I haven't had a chance to look at it yet.
Thanks in advance!
Tugboat
11-25-2003 17:42:43
 Re: 630 Carburetor in reply to Tugboat, 11-23-2003 17:42:25
Thanks guys! I think when my friend get the information you've provided, he'll be able to fix his problem!
Thanks again, Tugboat
John T
11-23-2003 18:17:43
Hey there Tug, When you say 2 small copper fuel lines and mention a possible problem of fuel in the crankcase, are you sure/mean they are connected to the carb, NOT a brass TEE on an auto shut off (oil presure operated) type sediment bowl assembly????? ????? ????? ?????
I have to ask that cuz if its equipped with the gas tank sediment bowl shut off assembly, they have 2 small lines to them (1 to oil pressure, other to oil pressure gauge) and if that shut off assembly has a leaky rubber diaphragm, thats a common source where gas gets into the engine oil. ALSO HOWEVER, I have seen them (2 lil lines) attached down at the carb with the shut off there, so that may be what you mean????? ???
REGARDLESS AND ANYHOW If it has the auto gas shut off assembly, they work by shutting off the gas if theres no oil pressure, and they can develop a leaky rubber diaphragm allowing gas to mix in the oil there. They automatically shut off gas if the tractor is turned off and/or theres no oil presure present to them. There is a brass looking TEE fititgn on them with one lil line to oil pressure and other to the oil pressure gauge, which is where gas can enter and get into the crankcase IF THE DIAPRHRAGM LEAKS.
They are not too expensive or difficult to repair, you can get the kit with the diaphragms and the o ring etc at Deere not too expensive. Be sure and get the disks and diaphragms in SAME WAY they came out and I usually also replace the lil o ring on the shut off plunger.
If it has one and its working and the sediment bowl is clean and clear, when the tractor starts, you can see how oil pressure (pushes a rubber diaphragm) causes the shut off plunger to lower letting gas fill the glass bowl. Or, you can unscrew the top lil knurled nut and push down and manually lower the plunger allowing gas to flow in. Theres BOTH gas and oil present there, which is how a leak can cause inbreeding lol.
So, if it has the auto shut off type sediment bowl, thats how it works and how its possible for it to be one possible cause of gas gettign into the oil.
Let us know, Good luck n God Bless
John T
Clooney
11-23-2003 17:59:13
Tugboat, some of those later 30 series tractors have the oil pressure controlled automatic fuel shut-off mounted on the carburetor.. If so there would be an oil line running to that.. If that is the case & the rubber diaphragm(s) are leaking, that could easily be the fuel leak back into the crankcase...To test.. Just pull the oil line & let the tractor sit,, if that auto shut-off is leaking you will see gasoline coming out of the oil line fitting.. Those diaphragms are replaceable & are [at least were] still available form Deere..
~There is also a carb vent line on those later 30 series tractors. That could be one of the lines in question..
~My money is on the oil pressure automatic fuel shut-off leaking..
[email protected]
Tyler-MO
11-23-2003 17:59:07
If he has a gasoline version...then those lines are vent and return lines. These most likely have nothing to do with fuel in the crankcase. These lines you are refering to are the oil pressure fuel shutoff. There are two rubber/neoprene discs inside the thing on top of the sediment bowl. When there is oil pressure it expands the discs causing fuel flow into the carberator...and when ther is no oil pressure it shuts off fuel protecting the crankcase from flooding with a stuck needle. The problem usually is a pencil led size hole in these discs allowing gas to enter the oil lines leading back down to the crankcase. Go to the local JD dealer and have them order you a new diaphram discs. Good luck
Tyler
