JD 60 Clutch repair
Rich
06-14-2001 18:14:58
I've never worked on Deere's before and I need a little help. I have a 60 with major clutch problems. I pulled the 1st set of facings and the drive gear/counterwieght off. It came off very easy - splines on crank might be bad? When I try to pull the belt pulley/ clutch housing off it moves about a inch very easily then stops. I can see loose pins etc.. rolling around on the inside in the bottom of the pulley. What is the trick to getting it off.
MarkinIN
06-14-2001 19:41:09
 Re: JD 60 Clutch repair in reply to Rich, 06-14-2001 18:14:58
Rich did you pull out the clutch fork on the front side of the pulley? It has to come out before the pulley will come off.
